Discussion topic: Satellite problem
This message was authored by: Richard320
Satellite problem
There is no satellite signal through the router
Re: Satellite problem
@Richard320
The router / internet does not bring a satellite signal. Your dish does.
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check/realign/repair/replace the dish/LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a previous post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
Your broadband router has nothing to do with a satellite signal problem. If you're seeing a no satellite signal message from your Sky box, it's a dish problem as @Daniel0210 posted.
