10
This discussion topic has been answered Discussion topic: Sky viewing card needs paired to sky hd
This message was authored by: Doncole
Sky viewing card needs paired to sky+ hd box
This message was authored by: Mark39 Answer
Re: Sky viewing card needs paired to sky hd
@AnnM2 if your Sky box is connected to the Internet you can re-pair the Card by carrying out a New Install. If it's not, you'll have to give Sky a call and they'll do it
Is this a replacement box, or one you 've had since before October last year?
This message was authored by: AnnM2
not replacement turned on tv and says sky viewing card needs to be paired to your sky+ HD box to pair them go to sky.com/quickfix but instead it keeps going to sky q.
What's the background to this? Do you have a SkyTV subscription? When did your Sky+HD box last work ok?
Yes it paid up to date, was working perfect. been away for 2 weeks on return this is on the screen.
no box is not connected to internet but can run a connection from it to internet if i can get it sorted myself. is this possible? as cant get through to sky until tuesday.
@AnnM2 yes, you should be able to. Worth a try if you'll otherwise have to wait until Tuesday.
That worked all sorted. Thank you
This message was authored by: Andy671
My sky box is not working and it is paired to my WiFi, the error message is CP01
@Andy671 doesn't sound like a Sky+ box, where you've posted.  Do you have Sky Q or Stream/Glass?
