Discussion topic: Satellite Signal
This message was authored by: Dotz21
Satellite Signal
Hello,
No satellite signal keeps appearing on my TV and it is causing me a major issue.
Can someone please help?
Re: Satellite Signal
Please Note: Sky+ is now a legacy service that Sky are winding down
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and other not)
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
