Discussion topic: Satellite Signal only working after rebooting
This message was authored by: HW9
Hi
We have a Sky + box. We keep losing our satellite signal but after switching of and on it works for a short while before giving us the message again - No Satellite Signal .
Checked dish and wires etc but no joy. Any advice anyone please.
Re: Satellite Signal only working after rebooting
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
