Discussion topic: SKY PLUS main & Mini Box - Valerian Busby
Message posted on 02 May 2025 12:56 PM
Hi I having major down time on both boxes. It freezes and or goes off line.
Each time this occurs which is about 5 times a day, I am having to turn off the box, wait till the box cools down and then reset them up.
Can I get a replacement of both boxes or a engineer to service the boxes. I believe that it has been between 5-10 years since these boxes were installed.
Val Busby
Message posted on 02 May 2025 01:03 PM
Re: SKY PLUS main & Mini Box - Valerian Busby
You've mentioned Sky+ AND a mini box. So please clarify whether you have Sky+ or Sky Q as the answer will be different.
@ValB1 Sky plus is now a legacy system which sky no longer sells or supports
Sky won't send an engineer or replace them but still give them a call to discuss your options about switching to one of sky's current systems Q (satellite), glass or stream to continue to receive sky tv services
Message posted on 02 May 2025 01:04 PM
See above
