Discussion topic: SKY+ HD BOX NOT WORKING
This message was authored by: rams01
Our SKY+HD BOX is not working. We have had the box for 11 years , should we just buy another box?
Re: SKY+ HD BOX NOT WORKING
Just giving us "Not working" is not enough info for people to give help 😞
@rams01 If it is "completely broken" then your options are to buy a used Sky+HD box from the likes of e bay (make sure to get a DRX890 or DRX895 model) or contact Sky to arrange a switch to Sky Q.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for rams01
Level 2 icon
Hi, Thanks for reply. We will try the box again later if it is still not working  think we will just go to a local shop and buy a new one.
Dont fancy the idea of trying to contact Sky. Do you have to pay extra for Sky Q.
You won't be able to buy a new Sky+ box, I'm afraid. They were last manufactured in 2015. You could buy a used one, either a DRX890 or DRX895  from ebay for around £30.
Your viewing package should cost the same with Sky Q, or less if you're currently out of contract and you sign up to a fresh one. There might be a cost to upgrade, but be ready to negotiate!
Avatar for rams01
Level 2 icon
Hi , if we do upgrade to sky Q can we get a sky engineer to come and set it up.
Yes, as a matter of course it will be installed by an engineer. They'll check your dish and cables at the same time and replace anything that isn't fully serviceable. Do be sure to check out the differences between Sky+ and Sky Q beforehand so that you know what to expect!
Avatar for rams01
Level 2 icon
Hi,Thanks for your reply . Whats the difference between Sky+ and Sky Q
If they're online, one of my Superuser colleagues, @nigea99 has put together an excellent brief which will help.
hi @rams01
that is a very broad question but as @Mark39 says I have compiled some notes which explain some key differences and factors to take into account for people looking to switch from SKY +/HD to SKY Q
SKY +/HD to SKY Q
It is  a little long but it does cover many points - some may be relevant to you, others not so.
If, after reading, you have any specific queries please do not hesitate to ask here and ,hopefully, we can answer
Much appreciated @nigea99
Avatar for rams01
Level 2 icon
hi, thanks for that. From what i have read I dont think we need Sky Q as we have only the 1 TV.
I will try to ring Sky tomorrow
Sky Q will work just fine with only one TV. You won't  need, and don't have to have a Mini box for use in a second room.
Avatar for rams01
Level 2 icon
Thanks to everyone .Would you believe the sky box is now working, well for now anyway.
@rams01 good to hear! Bear in mind it's at least 8 years old, and must, by now, be on borrowed time!
