Discussion topic: Rewind uk channel
This message was authored by: Mickey01
Rewind uk channel
My sky box will not record programmes from the rewind uk TV channel
Any ideas why ?
Re: Rewind uk channel
@Mickey01 what happens when you try? Do you se5e a Failed recording in your Planner? If so, highlight the failed recording and press i on your remote.  The failure reason will be displayed on screen.
This message was authored by: Johnrb1
I have the same problem nothing shows in the planner
Try emailing [email protected] (Viewer Relations Team)
@Mickey01
@Johnrb1
Recording fine here. What issues are you having?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
