Discussion topic: Replaced Multiscreen box prompting for upgrade
Message posted on 20 Jan 2023 06:42 PM
Place holder to enable a move of a message from another group
Message posted on 20 Jan 2023 03:41 PM
Re: Unable to watch a series I’ve added
Hi, I have sky+ with two extra multiscreen boxes. I recently had to swap one of the extra boxes as the first was failing. My daughter, who uses that box, has had difficulty watching downloaded HD programs. The message says she has to upgrade the package but, weirdly, she can watch that channel live.
Any ideas please?
Many thanks.
Message posted on 20 Jan 2023 04:39 PM
Hi @OperaJohn
You have posted in the Sky Glass / Stream board. You would be better posting in here:
https://helpforum.sky.com/t5/Sky/bd-p/sky-boxes
MikeAlanR
Message posted on 20 Jan 2023 06:46 PM
@mikealanr wrote:
Hi @OperaJohn
MikeAlanR
Thanks @mikealanr - I have moved to the SKY + group
Message posted on 20 Jan 2023 06:58 PM
Re: Replaced Multiscreen box prompting for upgrade
Thanks @nigea99.
Message posted on 20 Jan 2023 07:04 PM - last edited: 20 Jan 2023 07:04 PM
hi @OperaJohn
What channel are the programmes from - I am not up to speed with SKY HD multiscreen boxes so not too sure on how that differs from SKY Q.
I could be wrong but I think a couple of the core FTA channels (Channel 4 for example) can be watched in HD but need an HD add on to be able to watch HD downloads - but as I say I am not too sure on this & how the subs work for SKY HD
Message posted on 20 Jan 2023 07:06 PM
It's on "W" @nigea99. What I'm not sure of is how I check whether or not I have the HD add-on on the Multi-room boxes. I certainly have it on the main box and thought you had the same package on the others.
Message posted on 20 Jan 2023 07:10 PM - last edited: 20 Jan 2023 07:15 PM
If I remember correctly W in SD is FTA but the HD version even to watch need the HD sub so my theory may be incorrect - but I need to check this one out as well
EDIT : Yes W HD remains part of the pay channels and not FTA so needs the HD add on to watch in HD
W in SD became FTA earlier last year
Message posted on 20 Jan 2023 07:15 PM
When swapping boxes did you swap out the viewing card an pair it in its new box?
Message posted on 20 Jan 2023 07:39 PM
Message posted on 20 Jan 2023 08:02 PM
OK. I've just downloaded MasterChef Australia (not bakeoff; I got it wrong), on the other multi-room box and it worked perfectly. What I have noticed is that my daughter's box has the old menu - Search Bar at about 2/3s of the way up and 8 boxes (Guide, PLanner, Catch-Up, Boxsets etc.), - instead of the new.
Is that a question of updating the software?
