Discussion topic: Remove sky dish
This message was authored by: Sabriye9
Remove sky dish
I would like my sky dish removed from my property. It was here and inactive when i moved in. I do not watch tv and it is very okf and an eyesore to the property.
Re: Remove sky dish
hi @Sabriye9
SKY do not remove dishes - the ownership passes to the customer.
You can get any competent tradesman or DIYer to remove it - it does not need to be a Satellite specialist
Re: Remove sky dish
It's the property of the homeowner, not Sky. You would need to contact a local handyman to remove it for you.
Avatar for Sabriye9
Level 0 icon
Re: Remove sky dish
Thank you both for confirming. I asked sky on the phone and they said the same. Will call my dad to come and remove. Thanks again.
