Discussion topic: Remote
Message posted on 22 Apr 2025 10:59 PM
Remote
Message posted on 23 Apr 2025 03:51 AM
Re: Remote
@Lottie59 wrote:
How can I get a new remote?
Most larger supermarkets sell them. Also Argos or purchase online.
Message posted on 23 Apr 2025 07:54 AM
Re: Remote
@Lottie59 have you tried reprogramming your remote with the code for your TV?
Message posted on 23 Apr 2025 08:25 AM
Re: Remote
@Lottie59 wrote:
I'm having problems with my remote for sky +. I have replaced batteries but it is not working properly. I cannot adjust the volume or turn the tv off. How can I get a new remote?
If it is only affecting volume and TV on/off then that suggests that the remote isn't set up to control your TV correctly.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 24 Apr 2025 03:35 PM
Re: Remote
Im same my sound comes on but will not adjust up or down?
Message posted on 24 Apr 2025 03:38 PM
Re: Remote
@oj01's response applies equally in your case.
