Discussion topic: Remote pairing
This message was authored by: andrew+solomon
Message posted on 22 Jul 2025 09:46 PM
Remote pairing
Tv codes for pairing a new sky hd remote
Find out more
Message posted on 22 Jul 2025 09:53 PM
Re: Remote pairing
I assume you mean you need a code.
Unfortunately Sky's code finder website isn't working properly at the moment (reported a few days ago).
Here's a link you can use when the website is fixed: https://www.sky.com/help/program-your-remote
There's a faint chance someone might be able to suggest a code if you tell us the make of your tv.
Message posted on 22 Jul 2025 10:16 PM
Re: Remote pairing
i've sussed it, thanks anyay.
