Discussion topic: Remote control
This message was authored by: Bridie30
Remote control
Need new remote control mine is old and worn out . Where do I get new one and how much it is ? Thank you 🙏
Re: Remote control
@Bridie30 you can buy one cheaply from various online suppliers and local hardware stores, and probably your supermarket. Should be around £15.
Re: Remote control
At you local highstreet stores ie Argos etc.. or on-line at Amazon etc... Prices vary
Have you tried taking the existing reomte apart an cleaning the internals? This can bring it back to life depending on how it is "not working"
