Discussion topic: Sky box not connecting with tv
Message posted on 11 Dec 2025 03:00 PM
Sky box not connecting with tv. Picks up firestick ok. Have tried resetting & also updating. Neither of which have worked. Currently there is an orange light on the very right side. What else can I try?
Message posted on 11 Dec 2025 03:18 PM
Re: Sky box not connecting with tv
@Purpleday if this is a Sky+ box , the forum you've posted in, presumably it has connected before either to this, or another TV? Is it connected by an HDMI cable? Have you selected the correct HDMI input on your TV?
Message posted on 11 Dec 2025 03:32 PM
Yes, nothing has changed. We switched on the TV & immedietely the firestick shows on the screen, then when Sky button is pressed on remote for TV nothing happens. We have rebooted & updated the Sky box successfully in the past, but this time it dosent work.
Message posted on 11 Dec 2025 03:34 PM
Check this out: https://www.sky.com/help/sky-tv/sky-tv-plus/sky-plus-equipment/box-is-stuck-on-standby/articles/sky-...
