Discussion topic: Remote control volume button
Message posted on 08 Sep 2025 02:35 PM
Just had a new remote control delivered today for my sky+hd box. Everything is working except for the volume button.
Message posted on 08 Sep 2025 02:41 PM - last edited: 08 Sep 2025 03:24 PM
Re: Remote control volume button
You need to programme it with the correct code for your TV: https://www.sky.com/help/sky-tv/sky-tv-plus/sky-plus-equipment/my-sky-remote/program-your-remote/art...
Edited to add: with apologies @Rene4, it appears that Sky have removed their Sky+ remote code finder. You could try searching online, or post the make and model of your TV here, someone may know a code that works. If all else fails you could scan through all the codes stored in your remote to find one that works. To do that:
Press TV
Press Red and Select together until the red LED flashes twice
Press the TV and power buttons repeatedly until your TV switches off.
Then press Select to store the code.
Message posted on 08 Sep 2025 04:07 PM
Thank you for the information, but still did not work.
Message posted on 09 Sep 2025 01:13 PM
@Rene4 if you've been through the process I described - it will take quite a while - there's no code stored in the remote for your TV make and model.
