This discussion topic has been answered Discussion topic: Remote code for a Hisense 50A6GTUK
Message posted on 30 Sep 2023 04:48 PM
Re: Remote code for a Hisense 50A6GTUK
I've contacted Hisense again and spoke to a different person. He said that hisense do not provide codes and it was a matter for sky. Hisense provide a facility to add blue tooth control but this was not possible with sky IR devices. I went through the issue in detail and he agreed to refer this to the software development team and , at my suggestion, they contact sky to try and resolve the problem as a customer services issue. I gave him my email for him to advise any progress. Sky seem to think that using the no code method will pick up the appropriate code but I've tried this adnauseam without success. I'll contact sky directly next week.
Thanks for your interest. Any further thoughts?
I'll put off buying a version 10 until I contact sky.
Message posted on 30 Sep 2023 05:11 PM
It will IF there's a suitable code on the chip.
It seems odd that a previous code worked fine before but doesn't now, apparently because of a TV firmware update. Does the Hisense remote still work ok? And does the IR receiver light on the tv still flash when you use both remotes?
And just to check the Sky remote is transmitting - if you point a mobile phone camera at the end of the Sky remote and press TV then Standby you should see a burst of white light on your mobile screen
Message posted on 30 Sep 2023 07:52 PM
Yes both remotes working with respective equipment, Sky remote does not interact with red led on TV. White light burst appears on camera.
Message posted on 01 Oct 2023 04:53 PM
I have tried 2427 but I will try the other ones.
Cheers
Message posted on 06 Oct 2023 03:25 PM
I contacted sky technical support and relayed all the previous information. They suggested I try a v10 remote rather than my current v9f. They also advised a different coding method to that inmy sky box manual and appearing almost everywhere else on the internet.
The method suggested was
Press tv
Press select and red together
Enter code
Press select
I have just purchased a v10 sky+HD remote and using code 2429 have successfully controlled both volume and on/off using this method. It did not work with the v9f using this method. Neither did it work with the standard method suggested in the sky box manual( and that included with the v10 remote).
I hope this is useful to other Hisense tv users.
The sky technician is calling back next week to see how I got on so hopefully they will review their advice to users in their manuals.
Message posted on 06 Oct 2023 03:32 PM
Thanks for that. I will purchase a 10 controller.
