20
This discussion topic has been answered Discussion topic: Remote code for a Hisense 50A6GTUK
This message was authored by: Mitchjam75
My Hisense TV did a update. Now the sky remote does not work. I can't remember the code that worked. I have tried all the codes on sky. Hope somebody has another one that works.
This message was authored by: Annie+UK Answer
Re: Remote code for a Hisense 50A6GTUK
Your TV updating would not affect you remote control
How to program your remote control with no code.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
Avatar for Mitchjam75
Ok I'll try that.
This message was authored by: tins
The same happened to me . I've put in the old code (0536, which worked for 2 years) but it is no longer recognised. I've tried all the codes suggested by sky and others but no joy.Any suggestions?
@tins My FAQ shows the procedure to find an unknown code if one is available
Try resetting your remote first, by programming it with 999, then try again.
I've tried this but again no success. As I said I did not have a problem before the update earlier this week and have tried every suggestion on the web. Most frustrating.
My sky + remote is version 9F. I've tested that it is functioning by proramming it for a Samsung and it works fine.
I can't imagine why the TV manufacturer would deliberately change the code as part of an update. All you can do is try the 'every code' approach as @Annie+UK posted. If that doesn't find a code, there's no compatible code on the chip contained in the remote.
Why did it work for the last 2 years with 0536?
Presumably because that's what the TV IR receiver was originally programmed to receive. There's no way for the IR frequencies transmitted by the Sky remote using that code can have been changed.
Thanks for your advice. For the record my Hisense TV is model 55A7GQTUK.
Did this work? I did not for me.
I've just contacted Hisense support and they gave me a code of 2427 and also generic codes of 0532( which is the nikkai code in my handbook) and 8087. Could not get any of these to work.
Did they say they were codes for the Rev.9F remote? They might be for the latest Rev.10 .
