Discussion topic: Recorded listings wrong way round
This message was authored by: Amyjc
Hi, we had to change the sky+ box ...and now on the new box when you go to planner and what you have last recorded is normally at the top of the list however this new sky+ box puts it to the very bottom of the recordings ... is there anyway of changing this back around ... any help would be appreciated thank you
Re: Recorded listings wrong way round
@Amyjc
Give a planner rebuild a try:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes, don't do it if you are recording or due to start recording something. Your recordings and downloads are safe when doing this.
This message was authored by: ThePope27
You tried turning the TV upside down? @Amyjc
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Avatar for Amyjc
Hi ... thank you for your reply, i have tried your suggestion  for planner rebuild and this hasn't worked? It didn't show up as easy as you suggested in services, I had to Google it then had to press 0,1, select really quickly to get up a secret menu .. but as I said this didn't work 🤔 do you have any other suggestions that I could try please?
Avatar for Amyjc
@Amyjc
Press 'Services' and then press; 0, 0, 1, and then 'Select'.
Avatar for Amyjc
@ThePope27
Yes, that's what I did and it did the planner rebuild so i started it off and when I came back to it an hour or so  later the planner was still the same ... the wrong way around ?
