Discussion topic: Random channels working/not working
Message posted on 30 Dec 2024 08:15 PM
Message posted on 30 Dec 2024 08:42 PM
Re: Random channels working/not working
To confirm - this is a Sky+ box?
If so, try restarting it by switching off at the plug for 4 minutes.
Message posted on 30 Dec 2024 09:53 PM
If it's a Sky+ box (and not Sky+HD) many channels will no longer work, over the past 12 months a lot of channels have either switched to HD only or changed to a more modern transmission mode that isn't supported by Sky+ boxes.
Message posted on 30 Dec 2024 09:55 PM
Hi Ta
already tried several different things & this morning unplugged absolutely every wire, plug & connection for the sky box & router for 30 minutes while i popped out to the post office (basically i had to then connect everything like it had just arrived), still no joy
Message posted on 30 Dec 2024 10:02 PM
It only started to happen 2 hours ago & the channels i can & can't get varys every time i change channel (right now i can get 15 channels, 30 minutes ago i could get all of them & 2 hours ago i could only get Sky Max) oh & it sometimes lets me watch what's recorded & sometimes not.
Message posted on 30 Dec 2024 10:28 PM
@Pip-5 What are your Signal Strengths/Quality in Services > Settings > Signal?
All 4 white bars should be at least half way across.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 01 Jan 2025 05:05 PM
Hi, thanks for your help, but it has now completely packed-in & everything has gone black/white/blury, then turns itself off, having spoken to an old sky engineer, it's one of the rarer ways they go faulty & beyond repair.
ta
Message posted on 01 Jan 2025 06:13 PM
@Pip-5 wrote:Hi, thanks for your help, but it has now completely packed-in & everything has gone black/white/blury, then turns itself off, having spoken to an old sky engineer, it's one of the rarer ways they go faulty & beyond repair.
ta
Then your options are to switch to Sky Q or Sky Stream.
Don't be tempted to buy a used Sky+HD Box from anywhere as the viewing card can no longer be paired with it
