Discussion topic: Your Sky+HD Box isnt getting a satellite signal on both my sky boxes
This message was authored by: John964
on Both Sky+HD Boxes
Getting some channels
Re: Your Sky+HD Box isnt getting a satellite signal on both my sky boxes
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
