Discussion topic: Programme keeps turning of and on
This message was authored by: DonRitchie
Tv screen turns to colour liner checkerboard then black screen before switching back to programme.
Re: Programme keeps turning of and on
Whatever is happening sounds more like an issue witb your TV than your Sky+ box.
Does it happen when you use your TV's DTT tuner?
Avatar for DonRitchie
What’s a DDT tuner. It just happens while watching.
DTT = your TV's built in Freeview tuner.
You could try putting both your TV and Sky box in standby and removing the HDMI cable from both then swapping the ends over and reconnecting it.
Depending on the make of TV it may not support Freeview😉
