Discussion topic: Problems with chanel 512
This message was authored by: Boombomb
Hi I'm having trouble with chanel 512 GB NEWS. One minuet it's on and the next a no signal message comes up. It's just with this one chanel.  Anyone any ideas, thanks
Re: Problems with chanel 512
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q, Sky Glass and Sky Stream
@Boombomb
Fairly recently GB News and a few others moved to a different transponder that has a wider footprint which may result in a misaligned dish losing the channel. There are a few posts on the Sky Q board reporting similar.
@Boombomb
https://helpforum.sky.com/t5/Sky/Loss-of-channel-512-GB-news/m-p/4474741#M144234
