Discussion topic: Problem with my viewing card
This message was authored by: JonathanTang
Can’t get any Sky programmes on my TV and there is a message on the screening saying, "There is a problem with your viewing card".
Re: Problem with my viewing card
Try removing the Card and giving it a wipe with a dry cloth.
If you have not ordered Sky Q in the last couple of months and the order been canceled  then you could try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q
Additional help with your viewing card can be found here
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
This message was authored by: Gail17
Did you get this sorted? My mum has this problem as well
Has she tried the suggestions here?
I will try tomorrow - she is 87 so I will have to go to her house and try and sort it out!
