Discussion topic: Premier 1HD issue
This message was authored by: N0rthT1pp
Premier 1HD issue
I recorded the Munster v Bordeaux rugby match as I had to go out. I was home earlier than expected and selected the channel to view.
Got the message "your Sky + HD isn't getting a satellite signal".
Can one not watch a channel that is recording at the same time? All other channels are fine
Re: Premier 1HD issue
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
