7
This discussion topic has been answered Discussion topic: Parental settings
This message was authored by: Mickey14
Parental settings
I change the parental settings to say no pin is required for anything yet I'm still being asked during the day for a pin for any channel that is showing a rating of 12+. It's very frustrating
This message was authored by: Mark39 Answer
Re: Parental settings
You can blame OFCOM. Their mandatory daytime protection regulations require some content to be protected when viewed in the daytime, regardless of an individual's wishes
@Mickey14  It is a ofcom requirment that some programmes that would normally be post watershed shows need pin protection pre watershed https://www.sky.com/help/sky-tv/sky-tv-q/using-sky-q/settings-and-preferences-q-test/parental-settin...
@Mickey14
If you're watching age restricted content pre watershed then it'll always ask for the pin regardless of your settings. It is an Ofcom requirement that Sky must adhere to and cannot be overriden by Sky or you.
Avatar for Mickey14
Level 0 icon
Thanks. At least I now understand.
That's the trigger point: it's perhaps worth considering that until the expansion of Mandatory Daytime Protection control a few years ago such content couldn't be broadcast at all on any non-Cinema channel before the watershed.
https://www.ofcom.org.uk/tv-radio-and-on-demand/broadcast-standards/mandatory-daytime-protection
This message was authored by: brian300959
I also tried to set Parental Settings to avoid the PIN. Everything under "Family setting" is set to off, except "PIN on purchase". I have also checked that "Kid Safe Mode" is turned off. However, I am still asked for a PIN when I try to watch adult content DURING the post-watershed period. So it does not appear to be just about Ofcom requirements. Anymore thoughts welcome, please.
@brian300959
A Mandatory Daytime Protection challenge on broadcast content after the watershed is by definition a glitch, but could happen with on-demand access even though it's inappropriate.
Given Sky+ is now way past end of life and in use by a very small percentage of Sky television subscribers I very much doubt any remaining inherent issues are going to be resolved.
