4
This discussion topic has been answered Discussion topic: Some channels say there is no satellite signal
This message was authored by: Enjay1
Some channels won't work. I get a message saying there is no satellite signal. Sky+HD box.
It's channels like U&, MTV. Other channels like BBC, sky and itv work fine.
I have followed the help instructions, performed a restart, checked cables and signal. All should be ok but still some channels say there is no signal.
This message was authored by: Annie+UK Answer
Re: Some channels say there is no satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@Enjay1  A slightly misaligned dish can exhibit a loss of signal on channels that use a weaker european beam BBC, ITV etc use a UK focused beam so tend to be stornger signals.
In the event you would need to employ the services of  local satallite installer to check your dish as Sky no longer supports Sky+HD boxes.
This message was authored by: Nelly0
I don't have a satellite signal on my Sky TV box not working
See my post above
