Discussion topic: Pairing viewing card
This message was authored by: Phi007
How long till I get my sports back
Re: Pairing viewing card
@Phi007
Is this the same viewing card / Sky+ box combination you had in October 2024?
This forum is primarily customer-to-customer help, you're not talking to Sky support
Can you explain further?
@Phi007 Pairing to what the same box or a replacement, if the latter you won't get them back for the reasons below, if the former up to 4 hours from pairing
From 29th October 2024 sky has removed the ability to pair viewing cards to replacement boxes
viewing cards are now locked to the last box it was paired too (note: viewing cards are non transferable between accounts - hence buying a second hand box with a card included will NOT work)
any new viewing card sent will not work regardless of what you were told
you will need to call sky and discuss your options regarding upgrading to one of sky’s current tv products to continue to receive sky tv services
Avatar for Phi007
No sky channels
Anyone else?
Re: No sky channels
@Phi007 I'm assuming your most recent post is on the same subject.
Unless you've got something to add to your first post in light of the replies you've received, I'm not sure what more there is  for us to add.
Re: No sky channels
@Phi007
All you have said is
How long till I get my sports back and Anyone else?
You haven't actually explained what the issue is ?
