Discussion topic: On demand not working
This message was authored by: jrb63
Network connection is good but on demand not connecting
Re: On demand not working
@jrb63 try rturning off both your Sky box and your broadband router at the plug. Wait 30 seconds before restarting your router and another 4 minites before restarting your Sky box.
Avatar for jrb63
Tried this sequence (and several other reboot sequences). Does not clear fault.
Network is fine on all other devices incl Apple TV.
Sky+ box says connected to Network but fail for On Demand connection
Sky App remedy is no different - reboot sequence then says refer the internet provider. Thats poor.
Nothing else has changed on my system - was all fine 3 weeks ago
Not impressed the only Sky technical help is to push users at the Community.
Failing service of overpaid entity
How is your Sky box connecting to the router?
I find that a direct Ethernet connection causes the least issues
The youngest Sky+ HD box is now a decade old.
Does yours have built-in WiFi, or is it using an external Sky Mini connector?
