Discussion topic: Not working
This message was authored by: TeresaH
Not working
Hi
since we have had this bad weather my sky will not work
says it has no signal
weather is better today so I've turned sky off numerous times and still not working
can't even get into my planner either
keeps saying it's initialising then says to try again later
Re: Not working
@TeresaH
It might be that in the recent bad weather that your dish has slightly moved out of alignment, this possibly being the case you would need to find a local company to come out and look into this for you as Sky do not support Sky+ setup and have not done so for a few years now. Should you call them they will only send an engineer if you agree to upgrade to Sky Q.
