Discussion topic: No sky tv
Message posted on 16 Mar 2025 07:05 PM
No sky tv
No sky tv working - no satellite signal
Message posted on 16 Mar 2025 07:24 PM
Re: No sky tv
Unless you have Sky Protect in which case Sky will come out otherwise you will have to find a local company to you to look at this for you as Sky no longer supports Sky+ systems.
Before you do call someone make sure the cables are firmly in the back of the box.
Message posted on 16 Mar 2025 07:25 PM
Re: No sky tv
Its almost certainly a dish misalignment. Sky no longer support Sky+ and Sky+HD, but if you have Sky Protect through Domestic and General Insurance you can call them to arrange an engineer, otherwise you'll need to employ a local satellite engineer at your own expense to check it (or contact Sky to upgrade to Sky Q or change to Glass / Stream).
