Discussion topic: No sky signal
This message was authored by: Jay1012
No sky signal
Message says your sky+box isnt getting a satelite signa
Re: No sky signal
@Jay1012
The chances are your dish has moved during to storm Amy so as Sky do not support Sky+ setups you will have to engage a local company to come out and look at this for you.
Re: No sky signal
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
