2
This discussion topic has been answered Discussion topic: No sky channels
This message was authored by: Robert192
No sky channels
I have no sky channels.  Only BBC and itv channels.  The message reads that the wrong viewing card is fitted but I have not changed the viewing card which used to work.  What should I do?
This message was authored by: Mark39 Answer
Re: No sky channels
Is it the same card as was in use last October? Try turning off your Sky box at the plug for 5 minutes, and whilst it's off, remove the card and carefully clean the gold contacts with a soft, fluff-free cloth.
Re: No sky channels
Avatar for Robert192
Level 0 icon
Re: No sky channels
Yes it is the same card
