Discussion topic: No signal
This message was authored by: Jo429
No signal
The TV Guide comes up but when you click on a channel, it says searching for listings and then the screen goes blank
Re: No signal
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/.or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
