4
This discussion topic has been answered Discussion topic: No signal
This message was authored by: Knawer
No signal
No signal on selected sports channels.
This message was authored by: Annie+UK Answer
Re: No signal
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/.or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
Re: No signal
Re: No signal
@Knawer I assume you mean no satellite signal. Try turning off your Sky box at the plug for 4 minutes. Ifmthat doesn't help, the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
Avatar for Knawer
Re: No signal
Thank you,  Hoping to avoid losing recordings from 2TB box, collected over many years. Any way to save these?
Re: No signal
The only way to save stuff  is to record them to VHS, DVD, etc...
