Discussion topic: No signal
This message was authored by: Margaret118
Message posted on 18 Oct 2025 03:21 PM
No signal
No signal
Find out more
Message posted on 18 Oct 2025 03:27 PM
Re: No signal
Do you mean no satellite signal?
The cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
