Discussion topic: No signal
This message was authored by: Dan1100
No signal
Sky+ box isn't getting a satellite signal
Re: No signal
@Dan1100
The winds from Storm Amy might have moved your dish slightly so as Sky does not support Sky+ setups you will have to find a local company to come out to look at it for you.
Re: No signal
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Re: No signal
@Dan1100
As @caesarome indicates, Sky will advise you to move to Q, Glass or Stream.
