Discussion topic: No signal
This message was authored by: ChristopherBolt
No signal
No signal
Avatar for ChristopherBolt
Level 0 icon
No signal
Cannot get Sky on my tv?
I have turned the Sky box off several times, in the hope that would help.
I can get tv if I don't go the HDMI option, terrestrial tv I can get?
Re: No signal
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentFAQs: Sky GlassSky StreamSky GoSky Plus
