Discussion topic: No signal
This message was authored by: AnthonyHunt65
No signal
Sky + won't connect
Re: No signal
No signal? Or no satellite signal?
They're not the same thing.
Re: No signal
@AnthonyHunt65
If it's showing there's no satellite signal then you need to be aware that Sky no longer support Sky+ and Sky+HD. You'll need to employ a local satellite engineer at your own expense to check/repair/replace the dish if it's a dish issue.
If you have Sky Protect insurance through Domestic and General Insurance you can call them but a recent post suggested they wouldn't send an engineer - but did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
