Discussion topic: No signal
This message was authored by: Col44
No signal
Tuesday was the last time I saw the TV it said there was no signal at present but it did not stop me to see the planner as I had recorded a few channels that day I called it up but the next day it was same . I switched it TV off tried to restart the box but this time I cannot even go to the planner. I tried rebooting the Sky Box but sadly no joy, please help me fix this problem as the communal Ariel for the other tenants are working except mine.
Re: No signal
@Col44
No signal or no satellite signal? They are different.
edit: typo
Re: No signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Re: No signal
@Col44 the most likely cause is a fault with the communal system. It's possible for just one connection to the communal system to develop a fault, or it may be an issue with the cables from the communal system to your flat. For that, you will need to speak to your landlord or the managing agent.
