Discussion topic: No signal
Message posted on 04 May 2025 05:51 PM
No signal
I have an error code 25 and some channels are showing this and no signal
I have tried to reboot but with no success
the weather is fine
the dish hasn't moved
i am getting all channels on my sky go app
help
Message posted on 04 May 2025 05:56 PM - last edited: 04 May 2025 05:56 PM
Re: No signal
Almost certainly a slight misalignment of your dish. It's impossible to detect a slight movement at a glance. Unfortunately Sky no longer provide engineer support for + equipment unless you have Sky Protect so you would need to engage a local satellite engineer to take a look.
