Discussion topic: No signal on channel 406
Message posted on 04 May 2025 03:56 PM
My Input 1 Lock Indicator is not locked.
Message posted on 04 May 2025 03:59 PM
Re: No signal on channel 406
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
