Discussion topic: No signal
This message was authored by: Bigi
No signal
my TV is not working.  Do I need to book for an engineer?
Re: No signal
If you have a Sky+ box (where you have posted) then you will have to contact a company local to you as Skly do not support Sky+ boxes so will not send an engineer for this issue.
Re: No signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
