8
This discussion topic has been answered Discussion topic: No signal
This message was authored by: dottyp64
No signal
Every night at 6pm I loss signal for bbc2 & stv even though they have been working fine all day all other channels not affected so not this dish or the box any thoughts?
This message was authored by: Annie+UK Answer
Re: No signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Re: No signal
Avatar for dottyp64
Re: No signal
The rest of the channels are working fine watching bbc1 now & until 6pm stv works with no issues so I don't see how it can be the dish or the box
Re: No signal
Did you read my post??
Avatar for dottyp64
Re: No signal
Yes it sure you read or understood my message though
Re: No signal
Avatar for dottyp64
Re: No signal
But why does it work for rest rest of the day but not from 6pm if the dish was not aligned it wouldn't work at all not just in the evening
Re: No signal
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q for Signal Strengths/Qualities
Re: No signal
It can only be a problem at your end (as it were), otherwise everybody would have the same issue. So it's either a misalignment, a faulty LNB,  or box or faulty cabling. Of those the most likely are misalignment (signal strength varies slightly throughout the day) or a faulty LNB (the bit on the arm of the dish) - especially if it's more than 5 years old. There's also a remote chance of local interference.
