Discussion topic: No signal
This message was authored by: Bert70
No signal
Sky was working ok earlier
Now getting message MINI TV UNAVAILABLE NO SATELITE SIGNAL
Have tried switching off at mains and broadband off no help
According to settings I have a good strength of sognal
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Re: No signal
It looks like you have no signal from the dish on one of the two cables. Try switching your Sky box off at the plug and checking that the two dish cables are still securely fitted. If it's no different after switching back on, you'll need an engineer to check your dish set up for you. Unfortunately Sky no longer provide engineer support for Sky+ equipment (unless you have Sky Protect) so you'll need to get a local satellite installer to check for you.
Avatar for Bert70
Re: No signal
I unplugged at mains unscrewed the connection turned all back on o again sky came on but when I changed channels it wet off again what is MINI TV as I have this message
Re: No signal
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
Avatar for Bert70
Re: No signal
white part 50 % on each input
Re: No signal
The quaity is the more important if the 4 bars but 50% in my book does seem borderline, some systems can just about work but other will not 😞
This message was authored by: Joan+Rogers
Re: No signal
Have switched sky and TV off and back on but still shows no signal
Re: No signal
No signal? Or no satellite signal?
Re: No signal
I have channels but they are breaking up. I think it's the sky dish connection but I don't know how to make it right. I have switched off and on moved the sky box which seem to make difference but still no BBC1 or ITV. HELP
Re: No signal
i can't get escape to the country
Re: No signal
Yes, sounds like a problem with your dish setup. Unfortunately Sky no longer provide engineer support for Sky+ systems (unless you have Sky Protect) so you would need to engage a local satellite installer/engineer to come and take a look.
Alternatively now might be a good time to consider upgrading to Sky Q as your dish setup will be checked and put right at no additional cost, as part of the installation.
Re: No signal
OK. What's I pay my money every month for please????
Re: No signal
Every was fine this morning so why would it just go wrong????
Re: No signal
None of it has ever gone towards the maintenance of your equipment. Sky used to charge additionally for providing engineer support. Now you would have to pay a local engineer instead.
