Discussion topic: No signal
This message was authored by: Nick184
No signal
Switch on my sky message showing no signal available
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Re: No signal
@Nick184  A "No Signal" message is your TV message not a Sky Box message
