Discussion topic: No signal
This message was authored by: Emma19812
No signal
Once my sky box is on keeps saying no signal  been on settings on to the signal and no input signal I've checked all the wires they are in correctly but still no signal
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
