Discussion topic: No signal
This message was authored by: VickySingleton
Message posted on 08 Dec 2024 03:39 PM
No signal
No signal cannot get any channels on
Find out more
Message posted on 08 Dec 2024 03:45 PM
Re: No signal
Is that no satellite signal? You could try turning your Sky box off at the plug for 4 minutes. If that doesn't resolve it, the most likely cause is that your dish has moved slightly during the bad weather. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you would need to engage a local satellite installer to take a look. Or now might be an opportune time to consider upgrading to Sky Q.
