Discussion topic: No signal
This message was authored by: Adi5
No signal
I have recently moved home. Ive pkugged my box into the existing cabling and dish but getting no signal. The dish seems in good condition but does loot to have a birds nest behind it but nothing obscuring the front.
Any ideas
Re: No signal
Any ideas
hi @Adi5
Is it possible that previous occupiers had SKY Q  ?
SKY HD uses a different LNB (the electronic bit on the dish) to SKY Q
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Avatar for Adi5
Re: No signal
Sky have said similar re sky Q and have offered an upgrade. So that could well be it. Unbelievably though i have to wait til 10th of December for an engineer to upgrade me.
As the house doesnt have an ariel ill be watching a blue screen for a while. Dont get me started on the internet issues
