Discussion topic: No signal
This message was authored by: siraj56
No signal
Getting no signal. Input 1 signal strength and input 1 signal quality bar showing nothing. Input 1 lock indicator (not locked)
input 1 network ID (null)
Telephone line (not connected)
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
