Discussion topic: No signal
Message posted on 05 Jun 2024 02:16 PM
No signal
I am looking for someone who can help wit sky box
Message posted on 05 Jun 2024 02:22 PM - last edited: 05 Jun 2024 02:41 PM
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Message posted on 05 Jun 2024 02:25 PM
Re: No signal
Need engineer or upgrade spoke to someone who was very rude
Message posted on 05 Jun 2024 02:28 PM
Re: No signal
This forum is primarily customer-to-customer help
A phone number is given on a link on the page linked to below (click on the "Need more help?" drop down):
(make sure the correct country is selected at the bottom of the page)
How to make a complaint to sky: Sky Customer Complaints Code of Practice
Message posted on 05 Jun 2024 02:40 PM
Re: No signal
You have posted on the Sky+ board so as stated above Sky no longer support Sky+ and Sky+HD so won't send an engineer. If you have Sky Protest through Domestic and General Insurance you can call them otherwise you'll need to employ a local satellite engineer at your own expense (or upgrade to Sky Q or change to Glass / Stream).
