Discussion topic: No signal sky+ box
Message posted on 20 Aug 2025 02:23 PM
No signal sky+ box
Do I need a new Sky box and dish as the Sky+ boxes are going. Just have message saying Sky+HD is not getting a signal. I have been paying for a service I can't get
Message posted on 20 Aug 2025 02:27 PM
Re: No signal sky+ box
No signal or no satellite signal?
If no satellite signal I'm afraid Sky no longer support Sky+ and Sky+HD set ups. You'll need to employ a local satellite engineer at your own expense to check/repair/replace the dish/LNB if that's the problem.
If you have Sky Protect insurance through Domestic and General Insurance you can call them but a recent post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
Message posted on 20 Aug 2025 02:30 PM
Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect. You'll need to contact a local satellite engineer to take a look if you want to continue to use your Sky+ box.
The alternative is to upgrade to Sky Q or Sky Stream.
If you opt for Sky Q, any dish or cabling issues will be addressed on installation at no additional cost to you.
Sky Stream doesn't require use of a dish. Programmes are delivered via your broadband connection.
Message posted on 20 Aug 2025 03:06 PM - last edited: 20 Aug 2025 03:08 PM
Sky+ HD boxes aren't 'going' anywhere: Sky+ (SD) has already gone (in October last year)
